Sep 27, 2016 4:23 PM UTC
When creating a Problem Report can I limit the Select Affected Objects to WTparts only?
I want to limit users from linking directly to the CAD objects (or other files for that matter). How can I set it so only WTparts appear when adding items to the Select Affected Objects section?
Thanks in advance
Adam
Sep 27, 2016 4:41 PM UTC
You can create a Relationship Constraint for the Reported Against link and your Problem Report type (or Deviation/Waiver type) in the Type Manager.
Here are screenshots of a Windchill 11.0 example.  This has been available since Windchill 10.0
Note that only Part and the Part subtypes are not selectable/searchable as Affected Objects for the Problem Report
Oct 5, 2016 11:03 AM UTC
Jeffery,
Do you know if there is a way to set this using the windchill shell utility?  We are having issues with viewing the Relationship Constraints (still java UI in 10.2 M030).  I have logged a case, but anytime there are UI issues it takes a very long time to resolve.
Greg
Oct 5, 2016 3:12 PM UTC
Greg,
Not that I am aware of offhand.  All clients/browsers?
FYI - its in HTML in 11.0 F000
