7-Bedrock
Jun 5, 2025 4:26 AM UTC
When running the PTC Solution Installer (PSI) -->Update Existing Installation option is greyed out
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.1.2
We have Windchill 12.0.1.2 and trying to install the latest CPS available which will take the version to 12.0.2.25
via the MED-61006-CD-120_12-0-2-25_12-0-2-25-Bundle.
When running the PTC Solution Installer (PSI) -->Update Existing Installation option is greyed out. The article-CS41492 is not very helpful. Can anyone please provide assistance via Teams call?
Here are the errors that I faced
Cannot update when applying CPS patching due to "Update Existing Installation" greyed out.
    7-Bedrock
    Jun 5, 2025 5:02 PM UTC
    I restored the XML file from other instance into the appdata folder and verified the content. Its doing the update now. So, thank you!
    avillanueva
    23-Emerald II
    Jun 5, 2025 11:10 AM UTC
    Let's start with some basics. What OS are you running on? This can help us get to specifics. What is most likely the cause is the pointer file of the installation registry (psi_iir_index.xml) is missing. This could be because you are not using the same user account as who did the original install or possibly have shifted host machines and this information was left behind. The PSI is looking for this file to tell it where Windchill is installed. A number of causes are listed. Which one is likely closest to what you know.
    7-Bedrock
    Jun 5, 2025 4:45 PM UTC
    We have installed it on Windows 2019 Server. And using the same windows user account that we used to previously install the version. Since the PSI required Java 11 to be installed therefore, we upgraded Java from 1.8 to 11 on the machine and updated the system environment variables.
    I tried searching for  psi_iir_index.xml and found multiple files with similar names but not matching it with similar names as, psi_iir.xml, psi_iir.001xml, psi_iir.000.xml in separate folders:
    \ptc\Windchill_12.0\PSI\installer\instreg\
    \ptc\Windchill_12.0\PSI-WinDS\installer\instreg\
    I followed the resolution steps in the article with the exception that I could find
    <User_Profile>\AppData\Roaming\PTC\Windchill\
    It is still greyed out.
