Feb 29, 2024 6:04 AM UTC
when specific document created, we want to automatically create another document and attach as child
In the given code the child document which created automatically its failed to add as a child, and i tried with without linkage. The document is created automatically but after i tried to link it was showing error
@Override
protected synchronized void performStartupProcess() throws ManagerException {
super.performStartupProcess();
System.out.println("Registering CreateDocumentListener listeners...");
final ManagerService managerService = this.getManagerService();
managerService.addEventListener(new ServiceEventListenerAdapter(CreateDocumentListenerManager.class.getName()) {
public void notifyVetoableEvent(Object event) throws Exception {
System.out.println("DocumentDownloadListener notifyVetoableEvent POST_STORE ");
CreateDocumentListenerManager.addChildDocument((KeyedEvent) event);
}, PersistenceManagerEvent.generateEventKey(PersistenceManagerEvent.POST_STORE));
protected static void addChildDocument(KeyedEvent event) throws WTException, PropertyVetoException, RemoteException {
Object eventTarget = event.getEventTarget();
if (eventTarget instanceof WTDocument) {
WTDocument doc = (WTDocument) eventTarget;
// Check if the created document is of type com.windchill.WFActivityA
TypeIdentifier type = ClientTypedUtility.getTypeIdentifier(doc);
if (type.getTypeInternalName().equals("com.windchill.WFActivityA")) {
// Get the name and number of the parent document
WTDocument doc1 = (WTDocument) doc;
// wt.vc.wip.WorkInProgressHelper.service.checkin((wt.vc.wip.Workable) doc1, "Check in comment");
WTDocumentUsageLink linknew = new WTDocumentUsageLink();
// Find the TypeIdentifier for com.windchill.WFActivityB
TypeDefinitionReference childTypeDefRef = TypedUtilityServiceHelper.service.getTypeDefinitionReference("com.windchill.WFActivityB");
System.out.println("childTypeDefRef :"+childTypeDefRef);
// Create a new document of type com.windchill.WFActivityB
WTDocument childDocument = WTDocument.newWTDocument();
childDocument.setName("Child Document " + doc1.getNumber());
WTDocumentMaster masterChild = (WTDocumentMaster)childDocument.getMaster();
// Set the type definition reference for the child document
childDocument.setTypeDefinitionReference(childTypeDefRef);
System.out.println("childDocument :"+childDocument);
linknew.setRoleAObject(doc1);
linknew.setRoleBObject(childDocument);
WTDocumentUsageLink usageLink = WTDocumentHelper.service.createUsageLink(doc1, childDocument);
wt.fc.PersistenceHelper.manager.save(usageLink);
System.out.println("Created successfully !!");
HelesicPetr
Feb 29, 2024 10:54 AM UTC
Hi @AR_9920456
What is the error you are talking about?
The point could be that the original Document is not yet stored and listener event is triggered too early.
PetrH
Mar 15, 2024 11:07 AM UTC
I am unable to do save as the EPM Document. while save as its giving error in MS log
Error Message : "The value of "Owner Application" cannot be set to null, since it is a "required" attribute."
Mar 15, 2024 11:11 AM UTC
Sorry,this is the code iam using.
In this line error is poping up [ copyInfoArray = EnterpriseHelper.service.newMultiObjectCopy(originals); ]
private
EPMDocument saveAsCADAssembly(EPMDocument emptyCADAssembly , String name, String number) {
try {
RevisionControlled[] originals = new RevisionControlled[1];
CopyObjectInfo[] copyInfoArray = null;
originals[0] = emptyCADAssembly;
System.out.println("originals: " + originals);
EPMDocument copy = (EPMDocument) copyInfoArray[0].getCopy();
copy.setNumber(number +".SLDASM");
System.out.println("number set");
copy.setName(name+".SLDASM");
System.out.println("name set");
copy.setContainer(emptyCADAssembly.getContainer());
copyInfoArray = EnterpriseHelper.service.saveMultiObjectCopy(copyInfoArray);
} catch (Exception e) {
e.printStackTrace();
