Apr 13, 2015 9:35 AM UTC
When to use Promotion Request and When to use default workflow.
I want to take a Business Object(WTDocument) through a approval process.
The Process is simple with only three stages InWork,Review,Approved.
So Which approach to prefer...?
1.Call a promotion request on Document
2. Use a Workflow in the Object LC .
BenPerry
BenPerryAnswer
Apr 13, 2015 10:31 AM UTC
Avinash,
PR for at least 3 reasons:
  1. There are objects of that type that you will probably not want to promote sometimes. So don't use workflow in the LC because then it will force the object through unnecessarily.
  2. Multiple objects can be put on a PR, reducing the need for a PR for every single object.
  3. The system performance benefit to point #2 above.
BenPerry
BenPerry15-MoonstoneAnswer
Avinash,
apatil-212-AmethystAuthor
Apr 14, 2015 9:27 AM UTC
Hi Ben,
Thanks for the detailed explanation.
And I have decided to use PR .
Apr 14, 2015 5:43 PM UTC
Avinash, sounds like you should mark Ben's answer as "Correct Answer" then
