7-Bedrock
October 4, 2024
Where Used of multiple parts in one structure
Is there a way to search all structures/assemblies in Windchill to see where both Part A and Part B are used?
Where used only take a single part as input.
I would like a Where Used that can take multiple parts as inputs.
7-Bedrock
November 13, 2024
I will try it. Thanks.
Community Moderator
October 28, 2024
Hi @VL_10308942,
Thank you for your question.
Anurag
I assume that when you refer that "Where Used" takes only one input, you meant that in the UI.
If so, I think its the OOTB intention.
However if you want to see where used for more than 1, I suggest you use Reporting functionality.
Cheers
Hari
I made a simple report for you to take it from here.
I got the below output
Cheers
Hari
3-Newcomer
May 28, 2026
Hello, I completed the same report but I did not get any results.
Community Moderator
November 13, 2024
Hi @VL_10308942,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Anurag
