Mar 17, 2017 3:20 PM UTC
Why am I asked to check things out just to open a drawing?
I really need help with this. It bugs me. When I go to open certain things (drawings, assemblies, whatever) I am given the pop up window that says "This object is read only as it is not checked out" and gives me a list of things to check out. I can find no rhyme or reason to what it wants me to check out. For instance, right now, I am trying to open a drawing of an assembly. The drawing is in a released state, the assemblies in the drawing are in released states. All I want to do is open the drawing. Why on earth would I be asked to check out two (not all, just two) of the sub assemblies?
Any clues, hints, nudges in the right direction would be hugely appreciated. I'm sure there's some logic, I'm just completely missing it.
LoriSoodAnswer
23-Emerald II
Mar 20, 2017 7:30 PM UTC
Oftentimes the notice about objects getting marked as modified are tied to config.pro settings. The following article provides a list of config.pro settings that can be manipulated to prevent unwanted modifications: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS32596
22-Sapphire I
Mar 17, 2017 3:39 PM UTC
One common thing that leads to this:
- check out and change a drawing, but don't check out related model(s)
- change something in the drawing that in fact get saved in the model
- select to Continue for the model
- check in the drawing
- next retrieval of the drawing (possibly by someone else at a later time), message log says "drawing is more recent than the model"
Have to check out the model to apply the pending changes stored in the drawing.  These are "time bombs" in the system.
TomU
Mar 17, 2017 3:45 PM UTC
Choose "continue", then open the assembly and choose "save".  Look in your workspace and see what actually got saved.  Since it's an assembly, I would guess one of the models was changed but the assembly wasn't regenerated and save afterwards.  The next time the assembly is opened it sees it needs to update but to do so requires being checked out.  Sometimes relations, Pro/Program, and automatic mass properties calculations can also cause changes each time an object is opened.
LoriSood23-Emerald IIAnswer
23-Emerald II
smandel1-VisitorAuthor
Mar 21, 2017 1:50 PM UTC
Thank you all for your help. It's greatly appreciated. I think I have a better understanding and have stopped a good deal of the pop ups.
