Sep 28, 2016 8:14 PM UTC
Why is the processes zbcefr.exe *32 showing when running Creo3
Per below, these processes zbcefr.exe *32 run during Creo3 M100.  Why are they there and how can I get rid of them ?
We run Windows 7
Windchill 10.1 M040
I read some cases and threads, tried suggestions, the processes per above are still there after the suggestions.
Below is what I have tried.
Set the config options .........we run chromium_browser because IE comes up with script errors.
config options:
enable_3dmodelspace_browser_tab no
enable_partcommunity_tab no
enable_resource_browser_tab no
windows_browser_type chromium_browser
Also, set the Windows Settings to uncheck box "Expand the browser during startup" which updates the creo_parametric_customization.ui
Does not help either, any other suggestions?
TomU
TomUAnswer
Sep 29, 2016 12:35 PM UTC
These processes are the embedded Chrome web browser.  If you change the windows_browser_type back to using IE, they will go away.
TomU
TomU23-Emerald IVAnswer
TomU
Sep 29, 2016 12:36 PM UTC
By the way, they don't hurt anything.  We run the embedded Chrome browser here and are pretty happy with it.  The only thing you need to do is remember to manually kill these (with Task Manager) any time Creo decides to do an "unplanned exit".
18-Opal
Sep 29, 2016 4:25 PM UTC
From my understanding and to Toms point, you cant get rid of them, but setting the options that you mentioned will MINIMIZE the number of them that are started...
TomU
Sep 29, 2016 7:14 PM UTC
No, that's not correct.  If the windows_browser_type is not set to Chrome you won't get any zbcefr.exe processes.  Internet Explorer runs in a different process.
18-Opal
Sep 29, 2016 7:20 PM UTC
True Tom,  I should have stated when running the chrome browser....
Jul 26, 2022 8:10 AM UTC
You can get more information on this process in article CS229272
