18-Opal
Dec 5, 2017 8:21 AM UTC
why windchill use vault?
Hi
windchill has default vault, in my case path is "D:\ptc\Windchill_10.2_M030\Windchill\vaults\defaultuploadrootfolder"
and i create new master and folder.that path is C:\root_master_folder
after that i create new storage rule
storage rule was file that Domain is 'demo org' and type is 'EPMDocument' and status 'all'
file go to new vault
but it look like there is no difference
cause default vault and created vault size same
Configure vault to speed up windchill by reducing the size of the BLOB in the database
Is not it?
What is the purpose of using vault?
BenLoosliAnswer
Dec 5, 2017 3:16 PM UTC
All files go through the upload vault before going to their final location.
Initially they will be the same, until you do a Remove Unreferenced Files on the upload folder.
That will delete all files that have been moved and the sizes will be different.
BenLoosli23-Emerald IIIAnswer
TomU
Dec 5, 2017 6:25 PM UTC
Not necessarily.  If "wt.fv.forceContentToVault" is set to "true", content will bypass the default cache vault and move directly to the master vault.  See CS68929 for more info.
