May 28, 2015 5:12 AM UTC
Winchill Service Temporarily Unavailable
Hi all,
Do you experience this kind of error while opening windchill? After how many days of not opening the server because we re-arrange our office, now I cannot log on windchill and it prompt me in the browser "Service Temporarily Unavailable" The server is temporarily unabel to service your request due to maintenance downtime or capacity problems. Please try again later.
The server is up to 1 hr now and I get the same error in my browser. Please help.
Thank you.
Luar
7-Bedrock
May 28, 2015 6:23 AM UTC
Seems your Webserver is not running, when you type the Windchill URL (only the server name) without the "/appname" (usually /Windchill) will you get the "It works" feedback?
Luar1-VisitorAuthor
Jun 1, 2015 3:33 AM UTC
Hi!
It say "It works!"
May 28, 2015 6:56 AM UTC
Hi Cruz,
It's may be due to problem with Web Server.
Check whether Web Server is properly running through URL entry.
Also, check method server whether started properly.
2-Explorer
Jun 1, 2015 3:35 AM UTC
You should be looking at Method Server logs located at Windchill/logs directory. It will throw light on why the application is not running
23-Emerald II
Jun 5, 2015 11:43 PM UTC
Luar,
Were you able to get your method server back on line? If so, could you provide further details of the solution?
Thanks!
Nov 13, 2018 8:33 AM UTC
I get '503 - Service Temporarily Unavailable' when we open "~~ServerLink~~/Windchill/App".
It shows 'It Works!' message when we open only "~~Serverlink~~".
Please guide how you resolved it.
I checked Directory server & windchill service. Both are working.
