Apr 12, 2016 6:41 AM UTC
Windchill 10.1 installation
Hi all,
I am new to the Windchill installations and right now I am doing some trial installations on a Windows Server 2012 machine. I am installing Windchill PDMLink 10.1 and during the installation an error message appears: " java.lang.Exception: deploy failed for (wnc) with return code = 1" .
Do you have any idea what causes this?
2-Explorer
Apr 12, 2016 1:13 PM UTC
The error message is not descriptive enough.
Could you have a look at PSI logs at Windchill Load Point > PSI > Installer > Logs. Default location PTC\Windchill_10.2/PSI/installer/logs and the log would be named PSI Installer log. Search for the latest log.
Since it is WNC which failed, look for the installer logs for WNC in \PTC\Windchill_10.2\Windchill\installer\logs.
As a best practice make sure you don't have any spaces in the any of the CD's folder name and try copying the CD local if you are using a shared drive
Thank you
Binesh Kumar
ailut1-VisitorAuthor
Apr 13, 2016 6:34 AM UTC
Hi Kumar,
I found the error in the PTCSOLNINSTALLER_PtcINstall.log file, please see below:
DEBUG  2016-04-11 15:24:23 - checking URL connection to http://ro06-0008277.localdomain:8080  ...
DEBUG  2016-04-11 15:24:24 - Exception while attempting to connect (web service may simply not be running)
java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:351)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:213)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:200)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:529)
at sun.net.NetworkClient.doConnect(NetworkClient.java:158)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:411)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:525)
at sun.net.www.http.HttpClient.<init>(HttpClient.java:208)
at sun.net.www.http.HttpClient.New(HttpClient.java:291)
at sun.net.www.http.HttpClient.New(HttpClient.java:310)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:987)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:923)
at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:841)
at com.ptc.windchill.install.suite.runnables.AbstractWebService.attemptConnect(AbstractWebService.java:228)
at com.ptc.windchill.install.suite.runnables.AbstractWebService.isRunning(AbstractWebService.java:201)
at com.ptc.windchill.install.suite.runnables.AbstractWebService.stop(AbstractWebService.java:320)
at com.ptc.windchill.install.suite.SubInstallerManagerImpl.stopApacheIfApplicable(SubInstallerManagerImpl.java:385)
at com.ptc.windchill.install.suite.SubInstallerManagerImpl.process(SubInstallerManagerImpl.java:123)
at com.ptc.windchill.install.suite.SubInstallerManager.process(SubInstallerManager.java:14)
at com.ptc.windchill.install.framework.InstallAction.run(InstallAction.java:468)
at com.ptc.windchill.install.framework.InstallAction.install(InstallAction.java:313)
at com.zerog.ia.installer.actions.CustomAction.installSelf(Unknown Source)
at com.zerog.ia.installer.InstallablePiece.install(Unknown Source)
at com.zerog.ia.installer.GhostDirectory.install(Unknown Source)
at com.zerog.ia.installer.Installer.install(Unknown Source)
at com.zerog.ia.installer.actions.InstallProgressAction.af(Unknown Source)
at com.zerog.ia.installer.actions.ProgressPanelAction$1.run(Unknown Source)
DEBUG  2016-04-11 15:24:24 - apache already appears to be down.  Will not attempt to stop.
DEBUG  2016-04-11 15:24:24 - Backed up D:\SPLM\ptc\PSI\installer\instreg\ii26ee22d1.1540523216a.-8000\psi_iir.xml to D:\SPLM\ptc\PSI\installer\instreg\ii26ee22d1.1540523216a.-8000\psi_iir.002.xml.
DEBUG  2016-04-11 15:24:25 - SubinstallerManager - starting assembly: wnc
DEBUG  2016-04-11 15:24:25 - Dependency tree:
DEBUG  2016-04-11 15:24:25 - [wnc]
DEBUG  2016-04-11 15:24:25 - [wnc, ie]
INFO   2016-04-11 15:24:25 - ###################################################
INFO   2016-04-11 15:24:25 -          Running wnc Installer
DEBUG  2016-04-11 15:24:25 - calling executeInstaller(C:\Users\Admin01-Accenture\Desktop\WC Installation\Windchill 10.1 Services)
DEBUG  2016-04-11 15:24:25 - Processing subinstaller assembly (wnc): timer.start
INFO   2016-04-11 15:24:25 - Running:  C:\Windows\system32\cscript.exe //E:vbscript C:\Users\Admin01-Accenture\Desktop\WC Installation\Windchill 10.1 Services\setup.vbs WAIT LAX_VM C:\Users\Admin01-Accenture\AppData\Local\Temp\I1460380108\Windows\resource\jre\bin\java.exe -f D:\SPLM\ptc\PSI\installer\PSITempProps\wnc-installer.properties -DMULTI_PROGRAM_EXEC=1
INFO   2016-04-11 15:25:28 - Completed:  C:\Windows\system32\cscript.exe //E:vbscript C:\Users\Admin01-Accenture\Desktop\WC Installation\Windchill 10.1 Services\setup.vbs WAIT LAX_VM C:\Users\Admin01-Accenture\AppData\Local\Temp\I1460380108\Windows\resource\jre\bin\java.exe -f D:\SPLM\ptc\PSI\installer\PSITempProps\wnc-installer.properties -DMULTI_PROGRAM_EXEC=1
INFO   2016-04-11 15:25:28 - return code = 1
INFO   2016-04-11 15:25:28 - >>>> Replacing with return code = 2
DEBUG  2016-04-11 15:25:28 - Installation is Aborting.  The installation cannot continue.
FATAL  2016-04-11 15:25:44 - Aborting installation.
FATAL  2016-04-11 15:25:44 - Installation is Aborting.  The installation cannot continue.
FATAL  2016-04-11 15:25:44 - wnc installer failed to start.
FATAL  2016-04-11 15:25:44 - aborting: original exit_code = 2
FATAL  2016-04-11 15:25:44 - aborting: normalized exit_code = 2
DEBUG  2016-04-11 15:25:44 - SHUTDOWN REQUESTED
DEBUG  2016-04-11 15:25:44 - (X) commiting registry
DEBUG  2016-04-11 15:25:45 - (X) shutting down service manager
DEBUG  2016-04-11 15:25:46 - (X) cleaning up temporary directories
DEBUG  2016-04-11 15:25:46 - Exiting with exit code: 2
DEBUG  2016-04-11 15:25:46 - cleanUp()
DEBUG  2016-04-11 15:25:46 - calling cleanUpWin32()
2-Explorer
Apr 13, 2016 11:39 AM UTC
Could you paste relevant info from wncinstaller log from \PTC\Windchill_10.2\Windchill\installer\logs.
Also try removing spaces in your installation directories with  " _"
