Jun 25, 2013 3:31 PM UTC
WIndchill 10.1 M040
Has anybody had issues with tomcat ports using multi method servers and backgroundmethod servers in Windchill 10.1 M040?
Jun 25, 2013 3:34 PM UTC
If you accidentally configure to run more than one Solr instance, then
you will run into such issues.
Otherwise you shouldn't.
Jun 25, 2013 3:43 PM UTC
Jess,
Here is what I configured to install
New Installation
Windchill PDMLink
Windchill ProjectLink
Enable Remote File Server Support
- Windchill Index Search (Solr)
- Enable Windchill Index Search
Windchill Index Search Host Name
LMWC3.LawlerManufacturing.local
Directory to store Index Search Data
C:\apps\ptc\wc10_1\Windchill\solr\data
Windchill Index Search Port Number
8085
Default Indexing Language
English
Index Search Language List
- English
- Creo View
- Thumbnail Generator and Viewable Compression Utilities
Installing To: C:\apps\ptc\wc10_1\Windchill
Disk Space Required: 7.42 GB
Herb Miller
TWeatherford, Inc.
herbm@tweatherford.com
3148 Beach Blvd
Cicero, IN 46034
competitor"
Jun 28, 2013 1:54 PM UTC
Do you have multiple BGMS configured?
Even if you are using a Windchill cluster, with SOLR enabled, only ONE BGMS can have embedded Tomcat enabled.
There are many KB articles related to this, here is a good one to start with:
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS74622
While wt.tomcat.embeddedMode.solr seems to provide more fine grained configuration choices (YES, NO, ONLY), I have seen issues with this andrecommendusing the wt.manager.cmd.<bgms>.param.12=<null>to disable embedded Tomcat onall non-SOLR instances.
