Oct 6, 2014 10:22 PM UTC
Windchill 10.2 Identical Node Cluster
Hi
I am trying to configure a 10.2 identical node type cluster with two nodes obviously one of which will be the active master.
As per the Advanced Config Guide (http://support.ptc.com/WCMS/files/156979/en/WCAdvDeployGuide.pdf), the 2 properties that need to be set are:
wt.rmi.server.hostname=A
wt.cache.master.slaveHosts=B, C, D
Both these properties are set. But when I start Windchill, the MethodServer will start only on that node which is started first. For Ex. if I start Windchill on Node # 1 first, the Server Manager and the MethodServer both come up on it. But on node # 2 which is started after node # 1, only the Server Manager starts and never goes beyond the following line:
INFO : wt.manager.CacheMasterNegotiator - Master stub retrieved: ServerManagerImpl$MasterServerManagerImpl_Stub[UnicastRef [liveRef: [endpoint:[xxxxxxx.xxxx.xxx:5002](remote),objID:[-2dd23186:148e7679245:-7ffd, -7282938796370177322]]]]
No MethodServer on node # 2. If I go back to node # 1 and kill the Server Manager and MethodServer processes there, a Method Server process is initiated on node # 2 almost immediately. I believe whats happening is that the ServerManager on node # 1 starts and registers itself as the master (by putting the entry in the RMISTUBS database table). Then as per the expected functioning of a 10.2 cluster, the Server Manager on node # 2 appears to be waiting for the Server Manager on node # 1 to go down by checking the RMISTUBS table every few seconds and as soon as the SM on N#1 goes down it springs into action and starts a MS.
While this logic seems to be correct, I actually need the MS to start on N#2 as well while its SM is on the lookout for the SM on N#1 to go down. Isnt't that how it is supposed to be? Am I misssing something in the configuration here? Maybe something other than the 2 properties mentioned before need to be set?
May 17, 2017 11:48 AM UTC
Hey, did you understand the problem and got any solution? I'm also facing a similar issue of Server manger hang-up in an identical cluster node setup.
Please let me know if any fix you found. Thanks
Dec 21, 2017 8:30 PM UTC
We are encountering the same issue for a WC11 M030 installation. Appreciate if anyone can share the solution that solved the issue.
Sep 17, 2023 3:23 AM UTC
Same. @samahali , any chance you remember the solution 6 years back?
3-Newcomer
Apr 16, 2026 9:59 AM UTC
Open the port 5002
