May 31, 2014 8:09 AM UTC
Windchill 10 Eclipse Configuration
I have install Windchill 10 with Information modeler in my System but I think I have missed some jar file to configure I am getting compilation error while using the annotaions class and some other class as well can any one please help me to identify which jar files I should configure in my eclipse
Jun 2, 2014 12:33 AM UTC
try adding following jar(s) to resolve compile error
<Windchill_Home>\Windchill\srclib\tool\Annotations.jar
<Windchill_Home>\Windchill\srclib\annotations.jar
<Windchill_Home>\Windchill\tomcat\lib\annotations-api.jar
Jun 2, 2014 2:34 AM UTC
Hello Yogesh thanks for your reply I added these Jar but error is still there, one more thing I have install Windchill in one drive and Eclipse in other do you think will that be an issue ?
Jun 2, 2014 3:46 PM UTC
try to add jars from WEB-INF\lib. I have codbase as well and it worked for me.
Jun 3, 2014 3:21 PM UTC
Let PDMLink create a eclipse project:
ant -f bin/tools.xml eclipse_project
For more information have a look at the help
ant -f bin/tools.xml eclipse_project.help
Mar 22, 2017 6:20 AM UTC
Thank You Bjorn.. I will try to add a document on this.
John selvaraj D.
Dec 2, 2017 9:14 PM UTC
Some customization consultants would appreciate a way to build Windchill extensions on CI build servers that do not have Windchill installed on them. Therefore, it would be great if PTC Customization documentation described which specific jars need to be copied to the build environment so that Annotation Processing can generate and later compile without this error.
ShirishMorkhade
Dec 7, 2017 12:55 PM UTC
I have recently posted guidelines to configure Eclipse with Windchill. Here is the URL for your reference.
https://community.ptc.com/t5/Windchill-Questions/How-to-check-the-type-of-WTObject-and-run-an-expression/m-p/493835/highlight/true#M52868
I am sure it will help you in configuring Eclipse. Once done, it will configure all required JAR for you.
Shirish
