6-Contributor
Nov 10, 2023 7:45 AM UTC
Windchill 11.0 compatibility in Azure cloud
I want to use Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS11
Is windchill 11.0 supported on Azure cloud?
If it is supported , Can we use Azure sql database for installing Windchill.
    avillanueva
    23-Emerald II
    Nov 10, 2023 1:15 PM UTC
    I think all your questions are documented here:
    https://www.ptc.com/en/support/article/CS381955?source=search
    Its a Yes but...
    • Azure SQL Single database is the only configuration that is supported
    • Azure SQL Managed instance database is not supported
    • Azure SQL RTM is managed instance.
    avillanueva
    23-Emerald II
    Its a Yes but...
    6-Contributor
    Nov 14, 2023 9:46 AM UTC
    Hello ,
    We  are tried to install WC 11.0 in azure cloud , but we don't have any option to select cloud database instances.
    Please refer the below screenshot and suggest.
    Thanks.
    Nov 13, 2023 2:55 PM UTC
    My question is: Why are you trying to install a program that is 5+ years out of date. Windchill 13 is released.
    avillanueva
    23-Emerald II
    Nov 13, 2023 2:57 PM UTC
    My guess is that they are doing a cloud migration first, or at least moving the back end database.
