8-Gravel
Dec 6, 2021 5:18 PM UTC
Windchill 11.2 and SQL Server Issue
As per this thread, similar issue
HI all ,
How to config the eisting SQL database with Azure SQLDB
Dec 7, 2021 9:08 AM UTC
manjunath8-GravelAuthor
8-Gravel
Dec 7, 2021 9:28 AM UTC
Hi
Thanks for the reply.
I have configure and set up new Windchill 12.0 with Azure SQL DB.
I had Followed the Steps for IAAS ( Need to Upgrade Windchill 11.0 to Windchill 12.0 SQL Database)
1. Taken the existing Database of 11.0 and imported to 12.0
2. started the upgrade process , went well.
3. Windchill 12.0 is running successful with existing database.
For PAAS solution:-
1. Taken the Upgraded SQL Database.
2. Configured with the application
3. Since its Azure Managed instance Database i am not able to change the DB owner.
this is my Issues ,how to bring the Existing SQL Database with Azure SQL DB.
Please suggest.
8-Gravel
Dec 14, 2021 10:35 AM UTC
Waiting for your response
