Windchill 12.0.2.2 UpgradeManager fails in Execute Server Migrators, Update "TabLayout" pref
- 4 replies
- 3080 views
- Translate All
I am attempting, on a test server, to upgrade from 11.1 M020-CPS22 to 12.0.2.2. I have previously ran a plethora of successful upgrades of various versions including a recent 11.1 M20-CPS17 to 12.0.1.1. This is my first with a target system of 12.0.2.X.
So I have am very familiar with the upgrade process. We have customizations which I have incorporated into the target machine same as previous upgrades. However this time the Upgrade Manager fails in the Execute Server Migrators step on the Update "TabLayout" preference task.
I do have a case open with PTC and the TS initial response was: "The source of this particular error can be from multiple sources but the first thing to check are customizations. Did you implement and validate all source customizations on the target prior to running the UGM? We could also try knocking the target system down to a single MS monolithic system and see what happens."
I have tried the "knocking the target system down to a single MS monolithic system and see what happens" and it still fails.
I have attached the html file
<Windchill Install>/Upgrade/UpgradeReports/ExecuteServerMigrators/ExecuteServerMigrators-20211203-221112.html
file and stuck it in a 7z file because this forum refuses to take an html file.
Anybody have any ideas of what the Upgrade Manager is complaining about?
