Windchill 12.0.2.9 登录失败:无法定位 JNDI 适配器配置(No JNDI Adapter Configurations Could Be Located)错误
  • July 22, 2026
  • 23 views
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.9 系统登录失败,MS Log提示如下“ERROR [main] wt.method.server.startup.services - Failure to start manager wt.audit.StandardAuditService wt.services.ManagerException: Could not initialize Auditing service. Nested exception is: wt.util.WTException: (wt.federation.PrincipalManager.PrincipalManagerResource/CONFIG_ERROR_NO_ADAPTER_DEFS) com.infoengine.util.IEException: Info*Engine configuration error - No JNDI Adapter configurations could be located using the current Info*Engine settings. Contact your system administrator.” 修改IEConf/adapterservice.json 文件,没有生效 Here are the errors that I faced “ERROR [main] wt.method.server.startup.services - Failure to start manager wt.audit.StandardAuditService wt.services.ManagerException: Could not initialize Auditing service. Nested exception is: wt.util.WTException: (wt.federation.PrincipalManager.PrincipalManagerResource/CONFIG_ERROR_NO_ADAPTER_DEFS) com.infoengine.util.IEException: Info*Engine configuration error - No JNDI Adapter configurations could be located using the current Info*Engine settings. Contact your system administrator.”
18-Opal
July 22, 2026
Hi ​@AN_10542808,
Please refer to the article below.
https://www.ptc.com/en/support/article/CS361256?source=search
