3-Newcomer
Windchill 12.0 - Converting a Monolithic Environment to a Clustered Deployment
I am planning to convert an existing Windchill 12.0 monolithic environment into a clustered architecture and would like to understand the recommended approach and best practices.
My target architecture is:
  • Server 1
    • Apache Web Server
    • Windchill Master Node
    • LDAP
    • Background Method Server (BGMS)
  • Server 2
    • Database Server
  • Server 3
    • Windchill Cluster Node 1 (Method Server)
The objective is to have all user traffic routed through a single URL (e.g., cfplmtst.mycompany.com) hosted on Server 1, while the application workload is handled by the Method Servers running on the cluster node 1.
I am looking to understand:
  1. Whether it is a supported and recommended architecture to run only Apache, LDAP, and BGMS on the master node while hosting all Method Servers on cluster node.
  2. Best practices for configuring Apache load balancing and AJP communication between the web server and cluster node.
  3. Required host name resolution and DNS/hosts file considerations between the master node, cluster node, and database server.
  4. Any Windchill-specific configuration considerations when moving from a monolithic deployment to a clustered environment.
  5. Recommended approach for high availability, failover, and load distribution across the cluster nodes.
I would appreciate any guidance, reference architectures, or lessons learned from others who have implemented a similar Windchill 12.0 clustered deployment.
