Feb 16, 2023 2:43 PM UTC
Windchill
- 1 reply
- 683 views
- Translate All
I am working in a top level assembly & respective drawing. The changes are pretty simple.
But there are few sub level assemblies are coming as failed due to their component placement (Released state),...So, when I fix them locally (Workspace) & try to check-in the assembly & drawing, it gets successfully check-in but the drawing pdf (Auto created by Windchill) showing the incorrect placement of few parts from failed sub level assemblies.
Now, I want to fix this issue without revising the failed sub level assemblies. So that I can get the correct drawing pdf (as per local modifications that I have made).
Do you have any solution to tackle this issue?
