Feb 2, 2026 5:22 PM UTC
windchill
Version: Windchill Below 11.0
Use Case: start of Windchill User Interface
Description:
I have a small issue with starting Windchill, I tried to find the solution alone today but I can’t, I have the following error message:2026-02-02 15:57:36,162 ERROR [wt.intersvrcom.SiteMonitor.timer] wt.intersvrcom.SiteMonitor - Names=[master], URL=http://tls-vsrvdcns19.marc.fr.ssg:81/Windchill/servlet/WindchillGW, Status=SITE NOT RESPONDING, ResponseSeconds=1.003, TimeOfPing=2026-02-02 15:57:33.149 +0100
18-Opal
Feb 3, 2026 2:39 AM UTC
Hi @AL_10371359,
Is your Method Server instance Started?
If so, could you please share the Method Server logs?
If it is not Started, could you instead provide the Server Manager logs?
Feb 3, 2026 9:18 AM UTC
Yes the method server is launched,
See Methode Server.log
Thanks for your help
Best Regards,
Albert
18-Opal
Feb 3, 2026 9:32 AM UTC
I do not see any Method Server logs attached.
