Feb 10, 2015 4:07 AM UTC
Windchill
Hi need to Learn Windchill from Basics......
Feb 10, 2015 3:46 PM UTC
At what level do you need to learn it, user, administrator or installer?
PTC offers training classes for the first 2. You need to learn and document what it takes to install and configure a Windchill system.
If you have the software and licenses, start by doing an install, follwoing the steps in the PTC manuals. Docuemnt what you do along the way so you fully understand what you did. Then remove the software and do it again to be sure you recorded every step and command entry.
dravi1-VisitorAuthor
Feb 11, 2015 4:23 AM UTC
Need to learn as a user & as well as Administrator......Thanks for your Reply
Feb 12, 2015 6:42 PM UTC
You can also read through some of the guides for Windchill. Below is a link to the Windchill 10.2 Basic Administration Guide:
http://support.ptc.com/WCMS/files/156797/en/WCBasicAdminGuide.pdf
Below is a link to all of the reference guides:
https://support.ptc.com/appserver/cs/doc/refdoc.jsp
