6-Contributor
May 18, 2023 6:28 AM UTC
Windchill admin login Utility menu not display
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.3
Here are the errors that I faced
May 23, 2023 5:00 PM UTC
You may want to try testing your authentication using the wt.auth.Authentication utility. Instructions in the ticket:.
https://www.ptc.com/en/support/article/CS338401
avillanueva
23-Emerald II
May 23, 2023 8:06 PM UTC
Is this a new install or an upgrade? Could be a license issue with the admin user. Send more info.
18-Opal
Jun 1, 2023 5:08 PM UTC
Hello PC_10366408,
I'm Charles from PTC Technical Support in Europe: Was the information provided helpful somehow?
KR,
Charles.
