7-Bedrock
Jul 17, 2024 7:40 AM UTC
Windchill advanced search with csv-file?
Version: Windchill 11.1
Use Case: Search CAD-Documents in Windchill with a csv.-file.
Description:
Hi All,
I have a request to export a larger amount of CAD data from Windchill. So that I don't have to export them manually one by one, I wanted to do this via the advanced search and load them all into a workspace at the same time.
Is there a way to start an advanced search in Windchill using a csv file?
HelesicPetr
Jul 17, 2024 11:54 AM UTC
Hi @GS_4867400
Generally the answer is no.
The advanced search input is always in the UI not from a file.
Also you can use separator in the number as a semicolon ";" and search more objects by number at one search.
PetrH
HelesicPetr
Hi @GS_4867400
PetrH
Gian7-BedrockAuthor
7-Bedrock
Jul 22, 2024 5:06 AM UTC
My solution is now, to export the csv. to a notepad++ File and put all numbers in a row. From there i export the the numbers with semicolon ";" to the Windchill-Search.
HelesicPetr
Jul 22, 2024 7:02 AM UTC
That's it what I mentioned..
It is all what you can do and I think there is also some string limit for the search key.
PetrH
