Feb 1, 2023 5:47 PM UTC
Windchill allowing Iteration change on Released file
I am able to check out, modify, and check in a Released file. I am creating multiple Iterations of Released file. I do have some admin privileges, but I don't think I should be allowed to do what's described. Released Version/Iteration should be locked for Users. I don't even know where to start looking for cause. Windchill 11.1 Mo2o. Thanks.
TomU
TomUAnswer
Feb 1, 2023 7:17 PM UTC
Use two different logins - one for your normal work and one for your admin work.  It doesn't require any additional licenses.
avillanueva
23-Emerald II
Feb 1, 2023 5:54 PM UTC
If you have modify rights on that object in the Released or All state, you will be able to check it out and modify it. I would look at the policy admin and View ACLS for that object. See what rights are granted.
Feb 1, 2023 5:59 PM UTC
Typically the product manager can update the released objects.   Check the "TEAM" and see what role you have for that container & check to see if the ACL (Access Control List) is set correctly.  Designers and engineers should not have access to change any released state objects.
Feb 1, 2023 7:04 PM UTC
Thanks for quick responses. I see that I am a Product Manager. I don't know where/how to access ACL.  I spend 98% of my time as a Designer and 2% helping department by doing simple tasks like renaming and fixing common user errors. Is there a way for me to retain privileges, but not accidently make that mistake while doing Design work in Creo?
TomU
TomU23-Emerald IVAnswer
