7-Bedrock
May 16, 2024
Windchill+ and CATIAV5
Version: Windchill 13.0
Use Case: In order to connect CatiaV5 to Windchill+, 3° party Libraries are required to use Workgroup Manager ? In addition, also Theorem libraries have to be installed in order to publish with worker ?
Description:
i
Community Moderator
May 23, 2024
Hi @simo893,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Best Regards,
Community Moderation Team.
simo8937-BedrockAuthor
7-Bedrock
May 23, 2024
I'll try to explain in more detail.
In order to connect CatiaV5 to Windchill, 3° party Libraries must be installed on clients otherwise the Workgroup manager will not work.
My question is, if i have Windchill+ instead WIndchill, these libraries are still necessary ?
