avillanueva
23-Emerald II
Oct 12, 2022 2:50 PM UTC
Windchill and related apps running in SELinux
Checking to see if anyone has gotten this to work successfully. I've been trying to debug some weird PSI issues and failures. PTC articles have sent me down some rabbit holes as I have stumbled through one error message to another. I am circling back to this fundamental setup and trying to determine if it was the source of my issues all along.
My other post detailed issues getting a standalone instance of WindchillDS running. PSI fails to detect that WindchillDS is running and bails (windchillds installer appears to have failed to start. Its PTC and/or XML log is missing). I looked this message up and its not the tmp folders. Strange thing is WindchillDS is running. I can see the install, stop it and restart it. It looks fully installed except PSI did not finish.
I only find one posting (cs368618 ) that says "you are on your own kid" with regard to SELinux.
I'm going to try flipping to permissive mode. Perhaps I can see if OS is blocking something. I suspect poor error messages are leading me astray again.
20-Turquoise
Oct 12, 2022 3:30 PM UTC
We have had to make some tweaks to seLinux. Luckily we have a person on board that has some experience with this. It typically involves doing
audit2why < /var/log/audit/audit.log
and then running "semanage" and "restorecon"
20-Turquoise
avillanueva
23-Emerald II
Oct 12, 2022 3:34 PM UTC
@RandyJones strikes again. Thanks,
