Sep 2, 2022 5:19 AM UTC
Windchill API to unlock cad attributes ,which are locked in creo and update its value.
I am using Windchill PDMLink Release 11.2 and Datecode with CPS 11.2.0.1
    HelesicPetr
    Sep 19, 2022 11:38 AM UTC
    Hi @MS_10390550
    There is a reason that the attributes are locked.
    One of the reason could be calculation by relations in a Creo.
    If you update the value in a Windchill, Creo will update it based on the relation.
    So it is not good idea to change the value.
    If you want to change PDM attributes in the Creo, then try to follow article: cs195124
    allow_create_pdm_param to yes in config.pro allow you to change the WM parameters for new modes..
    PetrH
    HelesicPetr
    Hi @MS_10390550
    PetrH
