Dec 10, 2020 2:34 PM UTC
Windchill APIs for adding user selection files in publisher from java code doesn't work!
Hello all, I'm having a problem to select file for publishing in java code. I want to publish EpmDocument with selected one file from publish rule from java code as do it using Windchill New Representation Wizard! A new job and a new representation is created, but without any file, and it seems that adding user selections doesn't work! Does anyone have any idea how to do it?
Here is my source code:
String objRef = ObjectReference.newObjectReference(element).toString();
Publisher pub = new Publisher();
List<PublishParams> params = pub.getPublishParams(objRef);
for (PublishParams aParam : params) {
     ArrayList<AdditionalFile> selectedFiles = new ArrayList<>();
     if (aParam.getAdditionalFiles() != null) {
          for (AdditionalFile aFile : aParam.getAdditionalFiles()) {
               if ("xv3".equals(aFile.getOutputPrefix())) selectedFiles.add(aFile);
     if (!selectedFiles.isEmpty()) aParam.addUserSelections(selectedFiles);
pub.doPublish(false, true, objRef, (NavigationCriteria)null, (NavigationCriteria)null, false, "Custom Rep", "Custom Rep Description", Publisher.EPM, null, 1);
Here is a part of my publish rule xml file:
<additional-files name="publish_3dmodel_default">
     <file display-label="STEP" type="step" default="false" visible="true" locked="false" output-prefix="step"/>
     <file display-label="XVL" type="xvl" default="false" visible="true" locked="false" output-prefix="xv3"/>
     <file display-label="PARASOLID" type="PARASOLID" default="false" output-prefix="nondef_PARASOLID_SolidWorks">
          <option name="TargetSystem" value="SolidWorks"/>
          <option name="ExportContainers" value="Yes"/>
          <option name="ExportEmptyParts" value="Yes"/>
     </file>
</additional-files>
<if condition="is_cadpart">
     <publish on="create-representation" additional-files="publish_3dmodel_default"/>
     <publish on="schedule" additional-files="publish_3dmodel_default"/>
     <publish on="unknown-source" additional-files="publish_3dmodel_default"/>
     <publish on="manual-post" param-set="Additional Files Post Publish for Released Document 3D"/>
</if>
DejanSAnswer
Dec 14, 2020 10:08 PM UTC
In the meantime, I found the solution using method doRulesPublish:
pub.doRulesPublish(false, true, objRef, (NavigationCriteria) null, (NavigationCriteria) null, false,  "Custom Rep", "Custom Rep Description", Publisher.EPM, null, 1, publishParam.toString());
Here is my source code that creates a new representation with a single selected file by file format from publish rules:
public boolean doPublish(String id, String fileFormat) throws Exception {
        String objRef;
        if (id.startsWith("VR")) {
            ReferenceFactory rf = new ReferenceFactory();
            objRef = ObjectReference.newObjectReference((WTObject)rf.getReference(id).getObject()).toString();
        } else {
            objRef = ObjectReference.newObjectReference(ObjectIdentifier.newObjectIdentifier(id)).toString();
        PublishParams publishParam = null;
                    if (fileFormat.equals(aFile.getOutputPrefix())) selectedFiles.add(aFile);
            if (!selectedFiles.isEmpty()) {
                publishParam = aParam;
        if (publishParam != null) {
                "Custom representation", "Published by custom action", Publisher.EPM, null, 1, publishParam.toString());
        else {
            pub.doPublish(false, true, objRef, (NavigationCriteria) null, (NavigationCriteria) null, false,
                "Custom representation", "Published by custom action", Publisher.EPM, null, 1);
        return true;
DejanS1-VisitorAuthorAnswer
        String objRef;
        } else {
        else {
        return true;
