Jul 28, 2015 8:47 AM UTC
Windchill Approver Selection
I am uploading a document in windchill, as well i need a approval for the same by routing it through windchill.
How can i assign the reviewer/approver in windchill.
Do anyone know the process/step, kindly help me out
Prabhu
Jul 28, 2015 9:24 AM UTC
Prabhu,
You can create workflow for document approval and then link it  to 1st state of lifecycle (u need to use advance lifecycle ),so whenever new document is created/uploaded workflow process will start. Create workflow as per your approval process  i.e. add approve review and rework activities.
Check Windchill l help centre for more details
http://support.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=LCChp_WFProcessPhaseGateAssociate&action=show
else you can  define necessary transition in Document lifecycle for promote & lock  transition and use promotion request  for document approval
check help Centre for more details
http://support.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=LCStateTransDefine&action=show
Hope it helps
Shreyas
Aug 26, 2017 7:59 AM UTC
How to create a work flow in windchill
Aug 28, 2017 12:45 AM UTC
To create a Workflow Template you may refer to the Windchill Help Center : Creating a Workflow Template
For more information also refer to the topic : About Workflow Administration
Jul 28, 2015 12:01 PM UTC
It also depends on if you are using PDMLink or ProjectLink:
Option 1 of Shreyas's response is available in both.
Option 2 is available in PDMLink only.
For ProjectLink you can also use the "route" action on an object, which has I believe 5 default configured workflows that you can set up approvers and/or reviewers before kicking it off, as an ad-hoc approval process.
The option you choose also depends on the ability to search for the approval processes and record of approval as well, so make sure to keep that in mind.
