Aug 22, 2014 4:44 PM UTC
Windchill as an asset manager
Does anyone use Windchill to manage software licensing and maintenance or even other assets? I’m thinking of implementing this, but would like some ideas on how to approach it. Should we use WTParts or different object types? Any thoughts would be appreciated.
22-Sapphire I
Aug 22, 2014 7:36 PM UTC
Some thoughts:
- May want to include files, so probably use a WTDocument, not Part type
- May need some attributes so probably create a sub type of WTDocument
- Can constrain this Document Sub type to only be allowed to be created in
one special = purpose Library intended for just this purpose. Can use an
OIR to assign a different Lifecycle as needed, possibly 0, 1, 2, 3 Revision
sequence
- May want to use document structure if there are several related items
- Could have saved searches / reports that filter by state; states should
align with actions that need to be taken on the assets
Sep 5, 2014 7:14 PM UTC
Hi
what do you actually want to manage ? The paperwork (ie the terms of the licencing) or the number of licences you have free at any given time so you know if you need to buy new licences.
A) If it is paperwork, I agree with Mike. dedicated library, wtdocument, attributes, life cycle template
B) If it is about knowing how many licences you have for each software and how many you have left etc... I recommend a dedicated software for it. This is far too dynamic and fast pace changing for managing this as a document in a PDM
As you know you have many different types of licences, user, client, server, global, based on number of CPU etc... etc...
Windchill is not designed to manage such thing
In Reply to Tim Gudobba:
