May 19, 2016 9:53 AM UTC
Windchill Bulk Migrator Extractor Installation Failed with error build.xml :321: exec returned: 1
Hi All,
I am trying to install WBM Extractor on Windchill 10.1 M050 and it had failed every time whenever I try to install.
The build log is as below
!+! STARTED @ Thu May 19 15:18:56 IST 2016
  [taskdef] Created log dir 'D:\ptc_1\temp\buildlogs'
!+! ENTERING WBMExtractor[D:\ptc_1\temp\build.xml]
Overriding previous definition of reference to ant.projectHelper
Build sequence for target(s) `install' is [checkWindchillHomeDir, checkdeploy, deploy, setInstallClassPath, include-taskdefs, getinput-g, check-extract-xconf, xconfp, install]
checkWindchillHomeDir:
     [echo] Found windchill home directory: D:\ptc_1\Windchill_10.1\Windchill
checkdeploy:
deploy:
     [echo] java 1.6
     [copy] Copying 478 files to D:\ptc_1\Windchill_10.1\Windchill\codebase\com
     [copy] Copying 1 file to D:\ptc_1\Windchill_10.1\Windchill\srclib
     [copy] Copying 2 files to D:\ptc_1\Windchill_10.1\Windchill\lib
     [copy] Copying 1 file to D:\ptc_1\Windchill_10.1\Windchill\codebase\com\ptc\windchill\migration\wbm\wc2wc\extractor
setInstallClassPath:
include-taskdefs:
getinput-g:
     [echo] Backing up extract.xconf file to D:\ptc_1\Windchill_10.1\Windchill/codebase/com/ptc/windchill/migration/wbm/wc2wc/extractor/.wbmextractor/install
     [copy] Copying 1 file to D:\ptc_1\Windchill_10.1\Windchill\codebase\com\ptc\windchill\migration\wbm\wc2wc\extractor\.wbmextractor\install
!+! ERROR OCCURRED @ D:\ptc_1\temp\build.xml:321:  !!!
!+! FINISHED @ Thu May 19 15:18:57 IST 2016
!+! Log: D:\ptc_1\temp\buildlogs\0000-WBMExtractor.log
BUILD FAILED
D:\ptc_1\temp\build.xml:321: exec returned: 1
Total time: 1 second
I had followed one case provided by PTC. -
Document - CS186515
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS186515&art_lang=en&posno=1&q=build.xml%3A321&source=search
But even after that it is failing.
Can anyone help me in installing WBM Extractor ?
Thanks in advance.
Best Regards,
Aditya Achanta
May 27, 2016 10:17 PM UTC
Try upgrading your java from 1.6 to 1.7 - I think if you dig through your build file you will find a message regarding a class mismatch on a an encryption class.
aachanta15-MoonstoneAuthor
May 19, 2016 11:34 AM UTC
Hi All,
Please let me know if anyone is aware of it.
As I got stuck up with this.
Thanks and Regards,
Aditya
May 20, 2016 7:10 AM UTC
HI All,
Any inputs on WBM Extractor installation ?
In case if anyone is aware of it. Kindly let me know.
Thanks and Regards,
Aditya Achanta
