Jan 25, 2019 2:31 PM UTC
Windchill Business Administration Menu Problem
Hey all-
I am attempting to use some of the business administration tools on Windchill 10.1, build M040. I am using the Windchill client through Google Chrome. I am logged in as my organization's administrator, with full admin rights.
I am attempting to access the team administration settings through Organization > Utilities. When I click "team administration," I get an odd window that looks incomplete (See the attached screenshot). At first I thought it was loading, but I gave up on that after about 30 minutes of waiting.
I am wondering if anyone on the forum has seen anything like this before. I am fairly new to Windchill administration so hopefully there is an easy fix.
Thank you!
BenLoosliAnswer
Jan 25, 2019 2:35 PM UTC
Could be a compatibility issue between the Windchill code and Chrome. Be sure you have the right build of Chrome for 10.2.
Try using IE and see if you get what you want.
BenLoosli23-Emerald IIIAnswer
Jan 25, 2019 2:46 PM UTC
Tried it out in IE and got the same issue. However, there seems to be a Java compatibility issue. I will update and see if that fixes the problem.
Jan 25, 2019 7:21 PM UTC
Some of the administration in Windchill will not work in Chrome.  Some of the utility features still use Java and Chrome doesn't allow it anymore.
