2-Explorer
Jul 17, 2018 10:01 PM UTC
Windchill, Column Display, Parameters, HELP!!!!!!!
OK, Can someone please point me in the direction, or steps, or wherever i need to go, in order to get the display in Windchill, (commonspace, and workspace) to display a model parameter in the columns.    currently it shows number, name, version, state, file name. "Name" is the ptc_common_name
I know how to create custom columns, and change the columns, and organize all of that.
I however, want to replace the "Name" columm, with a "description" column.  The description is located in the model parameters under "DESCRIPTION"
The reason i dont want to use NAME (ptc_common_name) is because our BOM reports are pulling descriptions from the model parameters, and if that particular parameter isnt filled in, it shows blank in the BOM report.
(maybe there is a way to have the bom report pull ptc_common_name and it would be easier)
Jul 22, 2021 6:10 PM UTC
you have to have the parameters you want to see in windchill set to designate in parameters pop up.
Jul 22, 2021 6:20 PM UTC
I think you are asking about customized views in Windchill. Please follow below article.
https://support.ptc.com/help/wnc/r11.2.0.0/en/index.html#page/Windchill_Help_Center/UserSetupTableViewCustomize.html
