Oct 27, 2023 2:12 PM UTC
windchill commonspace folder cannot be displayed community
when I click on windchill commonspace after changing my network from VPN back to intranet in my office, I see an error:
Oct 30, 2023 12:42 PM UTC
it actually worked when i changed server to offline and back to online.
avillanueva
23-Emerald II
Oct 27, 2023 2:28 PM UTC
Obviously, there is a network interruption but its possible the server connection has gone offline. I would check Server Registry and possible toggle it offline and then back online. See if that works.
SM_1077330810-MarbleAuthorAnswer
joe_morton
Oct 30, 2023 6:48 PM UTC
Our VPN does this as well.. when you switch, your computer temporarily disconnects and reconnects. Creo will go to offline mode for any internet interruption. Once offline, you have to manually go back to online mode. It doesn't attempt to reestablish the connection on its own.
HelesicPetr
Oct 30, 2023 12:40 PM UTC
Hello @SM_10773308
From my experience if this error is shown and Windchill is online, the local Creo cache is definitely corrupted
So usually you need to delete the local creo cache and register the server again.
the OOTB place is in the user's temporary file location
C:\Users\userName\AppData\Roaming\ptc\ProENGINEER\Wildfire\.wf
https://www.ptc.com/en/support/article/CS208167
here is an article describes issues with Local cache corruption
https://www.ptc.com/en/support/article/CS43373
PetrH
