Jul 28, 2023 2:18 PM UTC
windchill DS 11.2.1 installation is getting failed
I am using Windchill PDMLink Release 11.2 and Datecode with CPS 11.2.1.0
we are doing upgrade from Windchill 11.1 to Windchill 12.1.2, and we are doing pre-Upgrade validation, we are installing windchill_DS 11.2 for windchill 12.1 , but windchill DS installation getting failed , so I am Unable to proceed further.
Here are the errors that I faced
The installation is aborting due to an unexpected error.
DEBUG 2023-07-28 08:43:15 - /ptc/windchill_11_2/WindchillDS/installation/ConfigWindchillDS.xml:81: exec returned: 6
avillanueva
23-Emerald II
Jul 28, 2023 2:27 PM UTC
I am not sure if this is specifically the cause but check that firewalls are open:
https://www.ptc.com/en/support/article/CS349167?source=search
If you can send more of the log that might be helpful.
jbailey
18-Opal
Jul 28, 2023 2:51 PM UTC
Make sure the exe isn't blocked... Also, I have seen other folks have issues based on the version of Java they have installed... Try running a command prompt as admin and launch the installer from that
Aug 29, 2023 3:14 PM UTC
Could you provide the error trace ? It could be due to a java version error.
This article could help https://www.ptc.com/en/support/article/CS349167
TomU
Aug 29, 2023 3:54 PM UTC
Which operating system?  Windows Server 2022 has some special requirements to get the old Windchill DS to install correctly.
Aug 29, 2023 4:15 PM UTC
Windchill DS 11.2 requires Java_Home set to Java 11.
Windchill DS 11.2 requires LAX_VM set to Java 8.
Install 8 first, then 11.
Use RegEdit to modify the LAX_VM to Java 8. It is set in 2 keys.
  1.       Computer\HKEY_LOCAL_MACHINE\ System\ControlSet001\Control\Session Manager\Environment
  2.       Computer\HKEY_LOCAL_MACHINE\ System\ControlSet002\Control\Session Manager\Environment
Relog, then do your Windchill DS install.
This works on both Windows 2016 and 2019, not sure of 2022.
TomU
Aug 29, 2023 8:15 PM UTC
You don't actually have to 'install' Java, it's just needs to be somewhere on disk and have a couple of environment variables set.  No registry editing is required.  PTC's installer for Windchill DS's needs Oracle's version of Java 8.  It will not work with Amazon Corretto.
jbailey
18-Opal
Aug 29, 2023 8:18 PM UTC
Windchill DS absolutely will run with Amazon Corretto. Been using it entirely since Windchill 11.2 - and used it (Java 11) to install Windchill DS 11.2 to Upgrade to 12.0.2.
