8-Gravel
Oct 18, 2023 2:42 AM UTC
Windchill Error while loading the Describe By document using linked to MPMStandardOperation
- 8 replies
- 2923 views
- Translate All
I am experiencing an error (as attached in the screenshot) when trying view the Document attached to the MPMStandardOperation on Windchill 11.1.
Furthermore, this is happening intermittently using a non-admin account only however this error is not appearing when logged into Windchill with an admin account.
Following is the snippet from the Method Server logs:
Resource bundle/Message key = wt.vc.config.configResource/1
(wt.vc.config.configResource/1) wt.vc.config.ConfigException: An element of the wt.fc.QueryResult"results" is invalid: all elements should be "wt.vc.views.ViewManageable"
Would appreciate any suggestion, how to overcome this issue.
