Windchill Export CAD Data List
Hello there,
I'm fairly new to these boards (first time poster, long time reader) and I cannot seem to find an answer to my problem.
I have been asked to export a list (in Excel or CSV format) of ALL parts, drawings, assemblies, etc. that exist in our system (along with their respective revision number). Is this even possible? If not, is there a work-around to get this information?
I'm thinking that it may be something that I can do in Report Manager, but unfortunately I cannot access this function (might be due to a Java incompatiblity?). If I do need to use Report Manager, can somebody please recommend the Java version that I should be using in order for Report Manager to work?
We are currently using Windchill PDMLink, Release 9.0, Datecode M050. If you need any other information, please let me know.
(Just an FYI, I saw on PTC that Datecode M050 was part of Release 9.1, not 9.0. However, my system is telling me it's 9.0. So it could be either one of those.)
Thanks in advance for any help!
Curtis
TomUAnswer
If you turn off any search limits or database query limits that have been set (as an administrator), you could then simply do a search and then export the results to the file type of your choosing. Depending on how much stuff you have in your system, this will probably bury the method server for awhile, so you don't want to do this during business hours.
TomU23-Emerald IVAnswer
Thank you! I will give that a try this afternoon, but I don't see why that wouldn't work!
I knew it had to be something I was missing. I'll post tomorrow and let you know if that's what I'm looking for.
Thanks Tom! This worked for me, although I kept crashing the server so I had to do it in pieces! Thanks again!!
