Jul 16, 2024 9:38 AM UTC
Windchill filter based extraction
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS22
I dont see the WBM in the Wthome/utilities folder. I want the Windchill filter based extraction to extract dataset from Windchill. How to get WBM?
    Jul 16, 2024 10:58 AM UTC
    Article - "[Knowledge Hub] Windchill Bulk Migrator WBMFF": https://www.ptc.com/en/support/article/CS319432
    Emeritus
    Jul 18, 2024 12:25 PM UTC
    Hello @NJ_11253659,
    It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
    Vivek N.
    Community Moderation Team.
    Aug 6, 2024 4:56 AM UTC
    I want to install WBM to my existing version. Which is the CPS that I should use for the same to get the upgraded version with WBM installed? Current version is: 11.0 M030-CPS22
