6-Contributor
Apr 18, 2024 5:00 PM UTC
Windchill Method Server StackOverflow error
We have been having the following error after a rehost:
2024-04-18 12:05:08,566 FATAL [main] wt.method.server  - MethodServerMain abort java.lang.StackOverflowError
at wt.util.WTProperties.getProperty(WTProperties.java:1421)
at wt.util.WTSystemProperties.getProperty(WTSystemProperties.java:100)
at java.base/java.lang.System.getProperty(System.java:854)
at java.base/sun.net.NetProperties.get(NetProperties.java:94)
It does not happen initially and the new instance will run fine but if we restart the instance of Windchill or refresh the database, we are presented with that error. I have tried to resolve this with CS370256 but we are stuck at this point.
Emeritus
Apr 23, 2024 6:51 PM UTC
Hi @ZahyMatar
Thank you for your question.
I encourage you to bring more details and context to your initial inquiry. This will make it easier for you to receive meaningful help from other Community members.
jbailey
18-Opal
Apr 23, 2024 10:08 PM UTC
Which version of Windchill? Did you use the rehost script, or manually rehost?
ZahyMatar6-ContributorAuthor
6-Contributor
Apr 24, 2024 2:34 PM UTC
We are using Windchill 12.0.2.4.
We ran the rehost script.
