Sep 20, 2022 3:29 PM UTC
Windchill mksapi-jar support for JDK 11 ?
could you give me a hint ... I am looking for a table to see,
which mksapi.jar version requires/supports which JDK  version / is used for testing by PTC.
I ask because we are not sure if JDK 8 is required/supportet or if we can also use JDK 11..
We use Windchill .v12.4 and access its API via mksapi-jar-4.16.2671.jar .
Thanks for your support.
Ron
Oct 11, 2022 5:46 PM UTC
Yes, good idea 😉  I opened a case at PTC ...
PTC suggests to use JRE v8.x matching to the used Operating System also for the java-program using mks-api.jar
At the moment newer JRE versions >8.x are not certified (meaning that there were no tests performed by PTC team on those versions).
Sep 20, 2022 4:25 PM UTC
Windchill 12.0.2.0 Software Matrices | PTC
From that document, only 11.0.11 is the tested release.
Java 8 was good for all release of Windchill 11.x.
Sep 20, 2022 5:35 PM UTC
Thanks a lot for your fast response with the linked  Windchill 12.0.2.0 Software Matrices | PTC , That's what I was looking for!
I would interpret
if  *Java (JDK 11.0.11 )  is a required component for the Windchill server"
I shall also it, when I access the server API via mksapi-jar-4.16.2671.jar.
Means I shall prefer JDK 11 and do not use JDK 8
Right?
Thanks in advance!
LE_101487791-VisitorAuthorAnswer
