May 22, 2026 6:35 AM UTC
Windchill MPMLink API
I am able to extract process plant details from Windchill MPMLink using the Java API, such as process number, name, and description.
Is there any additional API available that can be used to extract operations, skills, tooling, and other related manufacturing information associated with the process plant?
If such an API is available, could you please share the relevant Java API details or documentation with me?
Best regards,
Shrikant Bhosle
18-Opal
May 22, 2026 6:45 AM UTC
Hi ​@SB_10566278,
The following API can be used to retrieve the relevant information.
You need to pass the appropriate link class in the API accordingly.
StructHelper.service.navigateUsesToIteration(Iterated iteration, Class iteratedUsageLinkClass, boolean onlyOtherSide, ConfigSpec... configSpecs)
