Oct 18, 2022 5:26 PM UTC
Windchill naming of tablespaces
I am working with a University IT department to host the Windchill database. In the installation guides for Windchill 11.0, it seems that it's rather rigid in the naming of tablespaces expected for the application. Can these be changed to meet the department's standards?
avillanueva
23-Emerald II
Nov 17, 2022 3:43 PM UTC
@TomU , I think @AZ_9656599  was not asking about database files and SID convention. I found this in knowledge base that say you can modify default tablespaces but you have to manually build DB:
How to install with alternate tablespace names in Windchill PDMLink
Agree with @BenLoosli , that you should be installing latest version or even look at cloud hosted option.
Oct 18, 2022 5:43 PM UTC
My question is: Why are you installing Windchill 11.0? There is no support any longer for 11.0 (or 11.1 after Jan. 2023 and 11.2).
I do realize that versions prior to 11.1 do not have license requirements, but if this is what you are trying to avoid, you really need to rethink your strategy and long term usage.
The tablespace names are entered when you install the OCU for Windchill, so I would guess that the program will allow them to be any name you want to use.
TomU
Oct 18, 2022 5:47 PM UTC
Database files names and locations can be anything you want.  The Windchill application doesn't know and doesn't care.  I normally pre-configure the database manually and then just point the Windchill installer at the database (hostname, username, and password).
avillanueva
23-Emerald II
