Windchill not starting after cloning..
- 5 replies
- 2255 views
- Translate All
I trying to clone my production server for that i did the followed steps,
- Copy the Windchill installation and third party product at the same directory structure from the source machine to the target machine (windchill and Apache directory)
- Install oracle on the new machine
- Run the PSI on the target machine and install java , WindchillDS and OCU
- Import the Production database dump on the New machine’s DB
- Import the LDAP to the Windchill DS on the New machine
- If database is installed on the Production machine then no need to make any changes in db.properties file, else update “wt.pom.jdbc.host=<target host name>” in db.properties file of the target machine.
After completed the above steps i tried to start the windchill, but its not started. Herewith i attached the MS log file.
whether i followed the correct steps or anyone please suggest me the correct steps for that.
Waiting for your valuable reply!!!!!
