6-Contributor
Mar 21, 2024 6:41 AM UTC
windchill object check-in to site folder.
Windchill object is checked-in to the Windchill but not to the default container instead somehow check-in to the site level folder and the folder points to the workspace which user use at present. (Note: User performed the check-in form that workspace)
The site level folder (note: the name of the folder will be same as user current workspace) is not accessible directly from the site>folders. The folder can only be access by searching the object in Windchill and accessing the folder through the Breadcrumbs.
Because of this the object is only visible to the specific user who check-in and ADMINISTRATOR and other end user cannot see the object since it is still in his own workspace folder at site level.
(Note: The object won't be available when we access the workspace from browser UI as mentioned above it is only accessible by searching the object directly in browser and selecting the folder in Breadcrumbs)
I need to know how this happen and how to reproduce the issue. The issue is random.
20-Turquoise
Mar 21, 2024 1:33 PM UTC
According to PTC this is "Works to product specification for Windchill PDMLink". See article CS284273
https://www.ptc.com/en/support/article/CS284273
We opened a case in January last year on this 100% reproducible issue.
20-Turquoise
6-Contributor
Mar 22, 2024 7:43 AM UTC
Thanks for sharing the Article I am able to reproduce the issue:)
It was really helpful.
