Jun 4, 2014 9:42 AM UTC
Windchill objects link at DB level
Hi All,
I was exploring the objects link at db level. Is there any procedure or way/Utility get entity relationship links at db level.Need
guidance to understand.Kindly share your Ideas.
Example:
How "WTPART", WTDOCUMENT" "WTPartDescribeLink" tables are related in DB, which columns of part & document table has been mapped to WTPartDescribeLink table.
Chanhasen
22-Sapphire I
Jun 4, 2014 4:03 PM UTC
Not easy - and not very productive. Getting to know and work with the object model is far more useful.
Javadoc provides a lot of help.
Playing with query builder reports (Site, Util, Report Manager) also gives a lot of clues. Can look at the "view as SQL" code at various points when building reports, although this is grayed out when using certain functionality.
in general, most every table's primary key is IDA2A2. Relationships of Versions to their Master object are also important to understand.
Not much published by PTC over the years on this.
GregoryPERASSO
Jun 4, 2014 4:08 PM UTC
Once upon a time ..... Windchill UML data model in Rational Rose ....
No more since 10.0 .....
If someone has a great Reverse Engineering tool to build an explicit and functionnal UML data model from Java Annotation in Windchill 10. Please share !
Nov 20, 2014 2:57 PM UTC
Hi Chanhasen,
possibly solved?!
Right now I´m doing the same ... Working manually through the tables and searching for relationships.
Here an example of my results. If you like to I could share the whole datamodel (as far as I could collect the relationships between the tables).
greets
Ben
Chanhasen1-VisitorAuthor
Nov 20, 2014 3:24 PM UTC
Hi Ben,
Thanks for sharing the information.If possible ,please share the data model.
Chanhasen
23-Emerald II
Nov 22, 2014 12:26 AM UTC
This is a very complex question to answer. Mike is right.
In general, though, objects are usually associated through some sort of link or reference table. The ida2a2 values of the objects themselves (in their own db tables (WTPart, EPMDocument, etc)) will be in the RoleA (ida2a5, ida2a7, etc.) or RoleB (ida2b5, ida2b7, etc.) columns. There are usualy classname column associated with the RoleA and Role B columns to indicate what type of object the ida columns refer to (e.g. classnamekeyrolebobjectref, classnamekeyroleaobjectref, classnamekeya2a5, classnamekeya2b5, etc.)
Master tables (WTPartMaster, EPMDocumentMaster, WTDocumentMaster) are linked to the tables containing the info on the object iterations (WTPart, EPMDocument, WTDocument) are linked through the ida3masterreference column in the tables containing the iterated info.
Dec 31, 2014 12:48 AM UTC
I explained main link tables in my blog http://maheshmhetre.blogspot.com/
And to the specific question, to get the model diagram refer the article http://maheshmhetre.blogspot.com/2013/04/windchill-rose-web-publisher.html
This will work for Windchill 9.1 but not sure about the Windchill 10.x. Try and let me know if the model diagram available in 10.x
Mahesh
MarcoTosin
Nov 14, 2019 12:55 PM UTC
Starting from Windchill 11.0 the query builder tool can help you on this.
For example if you want to know how to join objects you can see on attached image, select the two objects type and then try to create a join.
On second image you can see a list of possible join but, if you check the above box, the system check for you only the real join (sometimes there aren't possible join and you have to add more objects to find a useful join).
Marco
