7-Bedrock
Feb 5, 2026 5:57 AM UTC
Windchill Office Worker Daemon (OFF) does NOT auto‑start.
I am using Windchill PDMLink Release 13.1 and Datecode with CPS 13.1.0.0
    Feb 5, 2026 10:01 AM UTC
    Is it supposed to auto-start since it's kind of OS service?
    7-Bedrock
    Feb 6, 2026 1:20 AM UTC
    It is intentionally not on auto-start by PTC. Since it is a Windchill service. not the windows service.
    it doesn’t come up before Windchill/WVS is ready. I want it to start the worker service as the server comes back up.
    Feb 10, 2026 8:35 AM UTC
    Have you looked at this:
    https://www.ptc.com/en/support/article/CS93677
    I take it your worker is on the same server as Windchill application?
    7-Bedrock
    Sep 2, 2026 12:19 AM UTC
    Hi Experts,
                      For current Office Worker, MS Office Application is invoked when publishing, since Windows System level and Office Application limitations, for some environment, Office Worker cannot work properly when worker daemon is running as service even if creating Desktop folder and switching logon user..., Office Worker works only when workerdaemon.exe is launched in foreground
                       --- As documented from Microsoft, Office Applications are not recommended to run in Service Mode --- Considerations for server-side Automation of Office | Microsoft Support
              There will be some incontinence when running workerdaemon.exe in foreground:
                       1. Once Worker machine is restarted, administrator need to log in Worker Machine and start workerdaemon.exe manually
                       2. If configuring auto-logon as recommended in Article CS93677, IT department may have concerns about system Security
                Is it possible to develop an alternative solution for Office Worker in future, which can avoid above limitations and incontinences
