Windchill PSI Oracle Problem
All,
I am installing PDMLink 9.1 M040 on an HPUX 11iV2 server with Oracle
10.2.0.4.0 on another server that is managed by our dba group. They
created a database and user for me to use. There is a default and temp
tablespace created. The dba group will not allow the PSI to run on the
Oracle server so I have to choose "Configure to an existing user on an
existing database" in the PSI. Well the installation was going great (for
4 hours) when it got to the database schema creation part where it failed.
There were errors about tablespaces that didn't exist and insufficient
privileges. My question is, should I have the dba create some tablespaces
that the PSI is expecting? What is the proper way to accomplish this type
of installation where the PSI is not allowed to run on the database
server? Here are some of the errors from the
PTCSOLNINSTALLER_PtcInstall.log:
1/4/11 4:37:38 PM: DDL Manager - configure DDL for Oracle
1/4/11 4:37:38 PM: ************ Found Schema to Load ************
1/4/11 4:37:38 PM: **** Running: su ptcadmin -c
/opt/ptc/Windchill_9.1/Windchill/bin/windchill
--java=/opt/ptc/Windchill_9.1/Java/bin/java
"--javaargs=-Dwt.tools.sql.warningOutputFileName=STDERR
-Dwt.tools.sql.errorOutputFileName=STDERR" wt.tools.sql.SQLCommandTool
create_ddl_wt.sql /opt/ptc/Windchill_9.1/Windchill/db/sql
errors:2871
warnings:11
1/4/11 4:39:36 PM: Installation is Aborting.
1/4/11 4:39:36 PM: The following log contains information that may be
useful for diagnosing installation problems.
1/4/11 4:39:36 PM: Please include it in your support requests.
1/4/11 4:39:36 PM:
/opt/ptc/Windchill_9.1/Windchill/installer/logs/WindchillDDL.log
The following log contains information that may be useful for diagnosing
1/4/11 4:41:13 PM: Aborting installation.
1/4/11 4:41:13 PM:
1/4/11 4:41:13 PM:
1/4/11 4:41:13 PM: -- Reason --
1/4/11 4:41:13 PM: Installation is Aborting.
1/4/11 4:41:13 PM: The following log contains information that may be
1/4/11 4:41:13 PM: Please include it in your support requests.
1/4/11 4:41:13 PM:
1/4/11 4:41:13 PM:
1/4/11 4:41:13 PM:
1/4/11 4:41:13 PM: -- Details --
1/4/11 4:41:13 PM: Problems running schema load.
1/4/11 4:41:13 PM: --- Summary of WindchillDDL.log ---
1/4/11 4:41:13 PM: - Exceptions -
1/4/11 4:41:13 PM: /* QA observed error: java.sql.SQLException: ORA-00902:
invalid datatype */
1/4/11 4:41:13 PM:
1/4/11 4:41:13 PM:
1/4/11 4:41:13 PM: - Messages -
1/4/11 4:41:13 PM: SQL ERROR in 'create_versioning_tables':
message=ORA-00959: tablespace 'INDX' does not exist
message=ORA-00942: table or view does not exist
'pdml/DDLBasic/com/ptc/wpcfg/doc/rule/create_variantspecid_seq_Sequence.sql':
message=ORA-01031: insufficient privileges
'wnc/WorkPackage/com/ptc/windchill/wp/baseline/create_WPBaselineSequence_Sequence.sql':
PATRICK S WILLIAMS
Information Technology
Mechanical Engr Solutions
Missile Systems
Raytheon Company
+1 520.545.6995 (office)
+1 520.446.0244 (pager)
+1 520.545.6399 (fax)
6221 S Palo Verde Rd
Tucson, AZ 85706-5093 USA
www.raytheon.com
Follow Raytheon On
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
Hi David,
You will have to create 3 table spaces manually BLOBS, INDX and WCAUDIT on
the DB server, drop the existing user and then then execute the create_user
SQL script which will crate the new user (same as the previous deleted
one)to give the Windchill DB user enough permissions on the TEMP and USERS
table spaces.
*Regards**,*
*Rohan Kalbhor*
*Delivery Module Lead - PLM Practice*
*MhpasiS an HP company
*Mobile : +91 9011759898 *
*** rohan.kalbhor@eds.com | -*
*3B076, Tower 4, Cybercity | Magarpatta City | Pune | India 411013*
On Wed, Jan 5, 2011 at 9:11 PM, Patrick S Williams <
-> wrote:
> All,
> 10.2.0.4.0 on another server that is managed by our dba group. They created
> a database and user for me to use. There is a default and temp tablespace
> created. The dba group will not allow the PSI to run on the Oracle server
> so I have to choose "Configure to an existing user on an existing database"
> in the PSI. Well the installation was going great (for 4 hours) when it got
> to the database schema creation part where it failed. There were errors
> about tablespaces that didn't exist and insufficient privileges. My
> question is, should I have the dba create some tablespaces that the PSI is
> expecting? What is the proper way to accomplish this type of installation
> where the PSI is not allowed to run on the database server? Here are some
> of the errors from the PTCSOLNINSTALLER_PtcInstall.log:
> errors:2871
> warnings:11
> 1/4/11 4:39:36 PM:
> 1/4/11 4:41:13 PM:
> 1/4/11 4:41:13 PM:
> 1/4/11 4:41:13 PM:
> 1/4/11 4:41:13 PM:
> 1/4/11 4:41:13 PM:
> invalid datatype */
> 1/4/11 4:41:13 PM:
> 1/4/11 4:41:13 PM:
> *PATRICK S WILLIAMS*
> Missile Systems*
> Raytheon Company*
> +1 520.545.6399 (fax)*
> Tucson, AZ 85706-5093 USA*
> **www.raytheon.com* [image: YouTube]<">http://www.youtube.com/user/raytheoncompany>
> [image: Facebook] <">http://www.facebook.com/Raytheon> [image: LinkedIn]<">http://www.linkedin.com/companies/raytheon>
> [image: Dual Band podcasts] <">http://www.raytheon.com/newsroom/podcasts>
> [image: Raytheon Sustainability]
> any information contained in this message. If you have received this message
> in error, please so advise the sender by reply e-mail and delete this
> message. Thank you for your cooperation.*
