Apr 26, 2016 1:23 PM UTC
Windchill Relationtionship Report SQL SELECT
I would like to produce a Windchill relationship text-file report for all Pro/E CAD Documents (epmdocument), using an SQL SELECT statement (Oracle).
The output would include the following info:
DOCTYPE, NUMBER, Version, relationship-type, Related-DOCTYPE, Related-NUMBER, Related Version
Example output would be something like this:
ProE Versioned Part,12345.PRT,A.1,Associated Drawing,ProE Versioned Drawing,12345.DRW,B.5
I am slightly familiar with the tables epmdocumentmaster and epmdocument.
But I don't know which table (and fields) contains the relationship (where-used) data.
Any suggestions?
Windchill 9.1
Gerry Champoux
Williams International
Walled Lake, MI
2-Explorer
Apr 26, 2016 3:16 PM UTC
For ASM to Part , use EPMMemberLink
select DISTINCT epm.cadname as "parent",epml.asstoredchildname as "child" from EPMMemberLink epml, epmdocumentmaster epm, epmdocument epmd
where epml.ida3a5=epmd.ida2a2 and epmd.ida3masterreference=epm.ida2a2 order by epm.cadname;
For Part,ASM to Drawing, use EPMReferenceLink
Regards
Binesh Kumar
Medtronic MITG
Apr 27, 2016 5:52 PM UTC
Binesh,
Thank you!
Before I try these, I need a clarification:
Both select statements appear to be identical.
In the second select statement, you said that I should use EPMReferenceLink.
Is that all I need to change? Is that the only difference needed?
Gerry
2-Explorer
Apr 27, 2016 6:24 PM UTC
My bad, Gerry. I am sorry. I thought I changed it before I pasted it. In the second query just change the table to EPMReferenceLink/.
The relationship remains the same.
Regards
Binesh
