Apr 10, 2017 3:47 AM UTC
Windchill rename issue
How to  do mass renaming in windchill ?
Apr 10, 2017 5:46 PM UTC
  • Multiple unrelated CAD Documents cannot be renamed at one shot because there may be several dependencies which cannot be handled at one time.
  • Multiple CAD Documents can be renamed if they belong to an Assembly:
In "Commonspace":
  1. Click "Product" or "Library" > Folder
  2. Select a top level CAD Document (i.e. top level assembly or drawing)
  3. Select Actions > Rename
  4. Include dependents
In "Workspace" (works for new objects only):
  1. Select a "Workspace"
  2. Select objects
  3. File > Rename
For more information, refer to : http://www.ptc.com/cs/help/windchill_hc/wc100_hc/index.jspx?id=CADxFileMenuObjRename&action=show
Jun 7, 2017 10:33 AM UTC
Hello Harshal
If all the parts are not belongs to the one assembly , is it possible to do the mass rename ?
I there any option to add those part to base line or any collector and then do the rename ? to my knowledge it is not possible even i tried any way .
If you know any method to do this please let me know .
Regards
Gagan
Jun 7, 2017 1:39 PM UTC
Yes - you can support rename from Search as well.  you can search for multiple part numbers with a ; separator
