11-Garnet
September 16, 2013
Windchill returns wrong findNumber
Hi all,
Recently I encountered a very strange Windchill behavior so I would appreciate if anyone can give me a suggestion what I did wrong. I got an assembly with three parts (part-001, part-002 and part-003) I added value for findNumber (in Windchill) attribute for every part (respectively 1, 2, 3) and then I checked in the assembly. After running the webject I got proper result (values for findNumber for the parts as given):
<ie:webject name="Query-Tree" type="OBJ">
<ie:param name="INSTANCE" data="<%=wtInstance%>"/>
<ie:param name="TYPE" data="wt.part.WTPartUsageLink"/>
<ie:param name="DIRECTION" data="uses"/>
<ie:param name="DEPTH" data="999"/>
<ie:param name="MODE" data="FLAT"/>
<ie:param name="OUTPUT_TYPE" data="OTHER_SIDE"/>
<ie:param name="AUTO_NAVIGATE" data="TRUE"/>
<ie:param name="SELECTEDBY" data="LATEST"/>
<ie:param name="OBJECT_REF" data="<%=obid%>"/>
<ie:param name="ATTRIBUTE" data="obid,name,number,usedFindNumber" delim=","/>
<ie:param name="GROUP_OUT" data="output"/>
</ie:webject>
Then I changed findNumber values a couple of times (checking in the assembly for every change), (last values were 11,12,13). Then I run the webject again and I was suppressed with the result, I did’t got findNumber values 11, 12, 13 but random value from previously added findNumer values.
I don’t know where the problem lies and what to do to get the right value (the last one) for the findNumber, please help.
17:49:15
Number
Name
usedFindNumber
  1. Ver./Iter.
0000000545
sklop-001
A12
0000000546
part-001
8
8
8
1
18
4
11
8
A1
0000000547
part-002
9
9
9
16
5
12
2
9
A1
0000000548
part-003
10
6
10
10
13
22
10
3
A1
Nenad
